- MrWizardModeratorMoved from technology
- How many watts? Series tends to be for larger systems with 400+ watts.
- RLS7201Explorer II:W
- JiminDenverExplorer IIConverting down the higher voltage in series will be less efficient than parallel and create more heat at the controller. You may also find issues when one of the panels are shaded.
- pianotunaNomad IIISeries wiring will almost certainly require the use of an MPPT charge controller which may be quite a bit more expensive.
How many watts are you planning on? - hypoxiaExplorerSeries provides a higher voltage which allows the use of smaller wiring to the controller. If wire size is not a factor then parallel is best.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
