Almot
Oct 04, 2013Explorer III
steveexplorer wrote:
...the 24v panels are the cheapest way to get lots of wattage with the smallest footprint.
You won't have the cheapest cost, the smallest footprint, and lots of wattage at the same time. Very rarely you can fill all the available space with 24 panels so that no space is wasted and there is no shading. Smaller panels will fill the space better so there will be more wattage, but the cost will be higher.
270W panel is a monster. It takes 2 people to lift and mount it on the roof.
If you can live off 540W AND if you can fit 2*270W 24V panels, go for it. Don's spreadsheet will tell you, more or less, whether your needs are within 540W. This will be cheaper than many small panels but you could likely get more wattage with many small panels.
It is easier (cheaper) to do things right from the beginning. 24 panels with MPPT controller need to be closely matched, for better efficiency. So if you think that you need 2*270W, buy both panels right now. For 540W you don't need 60A controller, 45A is enough.
I don't think there is such a thing as a cheap contractor :), in any trade. Especially in RV solar where they are trying to make it look like a sort of a black magic. RV shops are particularly useless in this respect. But there is a List of completed projects. Look at Mr. Wizard's installation, for example. Few aluminum angles for mounting brackets, a screw in the panel side, a couple of screws in the foot of the bracket.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
