KJINTF
Oct 11, 2013Explorer
Take a closer look at the specifications on the web site .........
Most (there are a very few exceptions) RV's operate with a 12 Volt house battery bank very few with a 24 Volt battery bank - I assume you have a 12 Volt battery bank, if so 600watts of solar array is the MAX Morningstar recommends for the 45 amp controller. Now if you have a 24 Volt or maybe a 48 Volt house battery bank then go for 1,200 or even 2,400 watt PV array.
The specification is for the battery voltage **NOT** the PV array voltage which can be as high as 150 Volts or even 600 Volts on the Morningstar MPPT controllers.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
