EsoxLucius
Oct 11, 2013Explorer
scroller95969, you are right, the TS-MPPT-45 is rated for 1200 watts maximum solar array input at 24 volts and two 300 watt 24 volt panels would provide only half of that. The MPPT controller will convert nominal 24 volts (actually up to 40 volts with some panels) from the panel array to accommodate an RV nominal 12 volt system. Even at nominal 12 volts the maximum PV array input rating is 800 watts when using Normal Operating Cell Temperature ratings which is more like real world conditions than the standard test.
Batteries do not provide input power to a solar charge controller, the PV panel array does.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
