Almot
Oct 12, 2013Explorer III
steveexplorer wrote:
We measured the roof and I can easily fit (2) 24v 300 +/- watt panels up there for starters.
So based on what I learned here I will be starting with (2) 24v 300+/- panels (600+/- total watts) with MPPT 45 or 60 amp controller to (2) 300 ah Lifeline 6v batteries (total 300 ah) to 2000w inverter?? Probably need to include a battery meter as well.
1) Shading - as somebody (SMK?) mentioned, make sure the panel is at least 16"-18" from the A/C unit, especially aft of the A/C where it's steeper, and at least 10" from lower structures like vents. Panel may "fit" but it may shade. Not everybody does this, but wherever possible, try driving those deck screws in panel mounting brackets into rafters, not just into plywood. The first rafter from the A/C is - usually - 16" or 18".
2) MPPT 45 should suffice, though 60 will give more margin for when you run some devices at the same time with charging (too long to explain).
3) Not sure about 6V Lifeline. Good brand but I recall in their manual that for longer life you should charge it at certain minimal charging current, and this minimal current is much higher than with other batteries brands, in fact it is so high that RV solar can't provide that much. In other words, they are not made for RV solar. At least, this is so for their 12V models.
4) Either battery meter or an optional remote controller monitor (this would be cheaper). Remote temperature sensor and voltage sense wire you'd better get with this controller, whether it's optional or not (I think with Morningstar both are optional).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
