time2roll
Oct 12, 2013Nomad
Lifeline calls for .2C or 60 amps for 300 amp/hrs.
Your 35 to 50 amps should be fine.
IMO the real issue is don't trickle charge at 5 amps because you will hang up in absorption too long. Also lead-acid likes to be charged so a slow rate leaves the battery discharged too long.
Use the charging manual to set the voltage points.
Manual see page 19
Manual see page 19
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
