NinerBikes
Oct 15, 2013Explorer
smkettner wrote:
1w per amp hour is a good baseline depending on usage.
2x G24 = 170. Less for just starage, maybe more if using the computer a lot for work etc. Less in the summer with no clouds, more in the winter with low sun and more clouds. Too little and you are back using the generator, too much and you spent more than needed. With today's low prices I would error on the high side.
1. Retired, don't use the PC for work, do use a Samsung chromebook... about 35-40w. And it does charge on 12v. Battery life is extreme on it, 6-8 hours, more than I can surf.
2. Mostly a late April through late Sept camper.... camping for me, follows the mountain biking and fly fishing seasons, usually to northern tier states, where the days are long.
3. I want this system to be portable, not a permanent mount system, I've no idea how long I will be keeping my current Travel Trailer, might want to upgrade, next owner might not want a solar system.
4. Is it worth it to get off the PWM type of voltage controller, considering I might later go to the GC-2 type of 6v batteries that are 225-240AH total, wired in series?
