CA_Traveler
Jun 03, 2015Explorer III
Empty Nest, Soon wrote:Install the new panels and see if you get house charging from both solar setups. If so you'll have more overall charging and then add a Trik-L-Start device to keep the chassis battery up.
I have been thinking of maybe switching the existing panels' output to the chassis batteries. (They're 25 and 75 watts, 100 total.) I have found that some items (e.g., radio) run off of the chassis batteries and I want to ensure the chassis batteries don't get run down over a long stay with no amps being replaced.
If for some reason the 2 systems don't play together nicely (most likely they will be OK) then connect the old one to the chassis battery.
