Empty_Nest__Soo
Jun 05, 2015Explorer
grizzzman wrote:
I agree you dont want to use the old panels with the new ones. Perhaps a test of the old panels are in order? A short curcuit amps test on a sunny day around 12 and 1 mid day. I would expect to see 4ish to 6ish amps between the two panels using the ten amps setting on your multi meter. This is on the roof close to the panels. If it passes move the controller and redo the wiring and if it fails chassis battery charger it is. What are your thoughts?
I'll take a few measurements and post what I find.
Wayne
On edit: Well, that will need to wait a while. By the time I got things together, the sun disappeared and black clouds moved in.
