Tom_M1
Feb 28, 2019Explorer
profdant139 wrote:My semi-portable solution:
The advantage of portable solar is that it is tilted properly and can be moved into the sun, while you are parked in the shade. The disadvantage is that you have to deploy it on arrival and pack it up when you leave.
I can lift the panels off by pulling two pins in each panel and set them out in the sun. If that side of the coach is in the sun, I can leave them in place and tilt them up. I also have a panel permanently installed on the roof. For a total of 385 watts.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
