BFL13
May 03, 2018Explorer II
You can over-panel the MPPT controller somewhat with no ill effects, because the controller self-limits the amps to its rating. (40 amps)
If you look at my previous post you will see the amps are all under 40 anyway. Your only danger is the Voc limit of 100 volts (150?). If each panel is 40 Voc(probably more like 38) that is total of 80 in series at 25C and higher when it is really cold. You can calculate how much higher at any colder temp by using your panel spec for voltage rise with temperature.
There is a' wattage for 12v and a wattage for 24v (double) but you only need to consider the wattage for your battery, likely 12v.
You can go over that watt limit because the controller self-limits. and anyway, besides those lower amp figures I gave, that's all with the panels facing directly into the sun at high noon, and yours will be flat on the roof so not even going to get that much.
So your 40 amp Tracer will be just fine with those two 280s. If you will be camping while it is freezing out, go parallel and stay well under that Voc limit.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
