Almot
May 04, 2018Explorer III
Series - easier to wire, no Y-splitters, thinner cable.
Parallel - need Y-splitters, "possibly" thicker cable and rooftop junction box.
Like Mr Wiz said, parallel is less affected by shading of one panel. This is the only reason to consider parallel, in your case. For camping mostly in the open - go series.
No difference for battery health, either way.
6*6V - either your battery bank is oversized or you're using daily too much energy for a boondocker. Consider using less. High-wattage appliances don't go well with solar (or need to be run on generator, rather than on battery). Obvious question, LED lights conversion - done?
