Almot
May 04, 2018Explorer III
y22man wrote:
I think they are building toyhaulers to be in full hook ups or run the gen all the time. They are putting elec only house refrigerators and such in them. They are advancing the tech but every little bit of tech takes power. Like I said, with 2 6 volts I would bearly make it 2 nights. 6 6v made it so I can make it 4 nights with the furness on the entire time. I typically boondock in the Utah mountains or desert. I go there to get away from the noise. So I don’t want to run the gen. The only time the TVs get turned on is if I need to charge the batteries, or if I am in full hookup campground like Kodachrome basin.
You're right, they don't design RV with offgrid camping in mind. Poor insulation is very common. 4 nights on 6*6V - it must be really cold where you are. Or something else is draining your batteries. If your fridge is all-electric, this would explain it. I've been using catalytic heater lately, mostly because with on-off cycling of furnace it's difficult to get a good sleep.
Red31 - by all means, be the judge, executioner or even Jesus Christ himself, if you wish so. Relax, anger clouds the mind.
