time2roll
May 05, 2018Nomad
y22man wrote:OK and what converter do you have doing the charging? I hope it is not a WFCO.
All lights are led. I think they are building toyhaulers to be in full hook ups or run the gen all the time. They are putting elec only house refrigerators and such in them. They are advancing the tech but every little bit of tech takes power. Like I said, with 2 6 volts I would bearly make it 2 nights. 6 6v made it so I can make it 4 nights with the furness on the entire time. I typically boondock in the Utah mountains or desert. I go there to get away from the noise. So I don’t want to run the gen. The only time the TVs get turned on is if I need to charge the batteries, or if I am in full hookup campground like Kodachrome basin.
I recommend PD9280-14.8
http://www.bestconverter.com/PD-9280C-148-80-Amp-RV-ConverterCharger
