Boon_Docker
Jul 29, 2018Explorer III
beemerphile1 wrote:y22man wrote:
...One question I have, what is the load terminals used for....
A load such as a light or radio or whatever can be powered directly from the solar power rather than the battery if you wish.
Not quite.
The load terminal does use battery power when the sun isn't shining. It is a terminal that you can set a time for on and off. It also has a low voltage cutoff so the battery does not drain too low.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
