Almot
Mar 27, 2014Explorer III
To have a controller "1.5 maybe 2 feet to the batteries" AND to ensure that on-board temp-comp doesn't work against you, you have to keep both controller and the batts in the same space, more-less.
Which means, you either have to put the controller on the trailer tongue out in the open - not recommended, or to put controller and batts in a big tongue box - OK for AGM but not so for flooded, or to put controller and batts into reasonably big storage nook - again, OK for AGM but with flooded there is an issue of venting, plus acid fumes affecting the controller.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
