Gdetrailer
Apr 03, 2021Explorer III
FWC wrote:theoldwizard1 wrote:
A typical diode loses 0.7V !
Yeah, something definitely doesn't add up here. Each cell in a solar panel only produces 0.5 - 0.7V (they are in fact diodes). The forward voltage drop on a diode is between 0.2 and 0.7V so you would loose half to all you voltage if there really was a diode between each cell.
Now, maybe he meant to say there is a diode in parallel with each cell, which would provide a bypass diode for each cell. This would provide slightly better mottled shade tolerance, but would increase the complexity of the panel. The linked data sheet doesn't mention this, so it seems unlikely to be true for those panels.
Typical diodes do drop nominal .7V, but Shottky diodes only drop about .3V.. Kind of doubt they would have used Shottky diodes but maybe perhaps they are, who knows..
So in reality even with parallel diodes were across each cell and you have 36 cells that would be 25.2V of voltage loss which basically eats ALL of the voltage produced by at least TWO of the series panels..
Now if they were Shottky diodes you would fare a bit better as that would be about 10.8V loss, but even that means you would need a series string of at least 3 or more panels just to get to some semblance of a charging voltage for 12V..
Realizing that would be worst case with one full panel completely shaded but still I don't think your going to see a very large difference if the panel has parallel bypass diodes or not..
Better yet, is to not park or place panels where that kind of shading may happen..
