PaoliExplorerJul 18, 2016Solar Question.Question: When I shut off the battery with the "shut off" knob inside the motorhome and park the vehicle for awhile, will the solar panel still charge the batteries?
wa8yxmExplorer IIIJul 18, 2016It all depends on who wired it up. How to be sure..Digital voltmeter. A resting 12 volt battery is around 12.6 Volts. if it's sunny out and the meter says 13.6,, The solar panel is working13.6 by the way is FLOAT so that would indicate a fully charged battery and a WORKING controller.14 indicates a controller fault
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
