Paoli's avatar
Paoli
Solar Question.
Question:
When I shut off the battery with the "shut off" knob inside the motorhome and park the vehicle for awhile, will the solar panel still charge the batteries?
  • Paoli wrote:
    I just want to know if it's better to leave the batteries turned on while parked for a week or so without using the motorhome.... It's obvious I would turn them off during winter storage. I guess I should ask the RV place that installed the panel.
    Yes, and that's why people suggested disconnecting the battery cables and checking them with a meter (assuming you have one and know how!). It all depends on how the panel/controller is connected to the batteries. Asking the installer would probably be a good solution too because it would take them 5 minutes to check if they didn't recall how they installed it in your particular case.
    Dave
  • I just want to know if it's better to leave the batteries turned on while parked for a week or so without using the motorhome.... It's obvious I would turn them off during winter storage. I guess I should ask the RV place that installed the panel.
  • Only you will know... it could be either way....
    unhook the battery terminal cables
    place the switch in the off position
    check the battery terminal cables for possible voltage from the solar gear.
    make sense ?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
