The problem with wooded and shady is the panel(s)do not produce enough voltage to actually charge the battery. I made a mistake when I purchased a 66 cell 185W high voltage panel on Ebay meant for a grid tie system which will put out no load 70+V. This required a MPPT controller that will convert that high voltage into usable current. What this means is that I get usable current from sun up to sun down and with shade. I have seen 17V from a full moon and typically 36V in a shaded camp site. The Morningstar SunSaver MPPT controller is about as bullet proof as you can make a solar controller.
