This is not a RV application but there seems to be a lot of solar knowledge on here so I thought I would ask. I run a 12V system in my remote cabin for LED lights and RV size water pump and CD play...
The OP didn't mention the security aspect. If you have a solar panel on the cabin will it be there when you get back in a couple weeks?
If we allow (dubious) that 230w and MPPT will be enough for a trickle charge in the deep woods, then a typical cost for that "up here" is about $260 for the panel plus tax and $110 for the Eco-Worthy 20amp MPPT.
So that is about $400 for this job, if it works and nobody steals the panel, instead of just taking the batts home between visits.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
