This is not a RV application but there seems to be a lot of solar knowledge on here so I thought I would ask. I run a 12V system in my remote cabin for LED lights and RV size water pump and CD play...
I believe BFL was suggesting supplementing the use of a more appropriate charger (on generator power), with the small panel, for continuous maintenance between charge cycles. The charger I suggested would indeed get the job done well within the OP's specified time frame of 8 hours.
The OP appears to only want to supplement generator charging with solar, not replace it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
