Mel_B_ExplorerMay 29, 2017Solar questionI just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...Show More
time2rollNomadMay 29, 2017Exactly what inverter was installed?Operation of any 120v item is independent of the solar charging the battery.Yes if the right component fails you could be out of luck until the item is fixed depending on what is affected.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
