I just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...
For what its worth, your Renogy kit does not come with a transfer switch, so most likely is that the tech that installed the unit ran power from the inverter to the portions of the system you now have power to them, and eliminated the connection to the shore power to those circuits. If you want the ability to select power source, both Lowes and Home depot sell transfer switch units and kits, basic 30 amp unit would run about $100 - $150 plus installation.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
