Mel_B_
May 29, 2017Explorer
Solar question
I just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...
Mel B. wrote:That actually sounds normal. The inverter/charger will run through it's own charging profile when plugged in. Give it time and it will drop to float. Looks like absorption should be 10x bulk. So if bulk on a charged battery lasts 1 minute the absorption should be 10 minutes.
It's a Renogy 2000 watt inverter/charger with a 30 amp transfer switch built in it. Solar is keeping battery bank charged. But when I plug into shore power inverter goes into boost mode, dip switch is on correct setting for my battery bank.
