I just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...
auto on inverter mode is basically a load sense, it doesn't use any power, doesn't need any power until you turn something on, it saves battery when dry camping, especially at night, when sleeping and you don't have the tv etc.. on, the inverter on idle battery drain goes way down
my tipplite is like that, at night if im not charging any thing and the fridge is not cycling, the inverter is about 200ma idle drain
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
