I just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...
Mr Wizard your right about that, it's how mine is. Also it's supposed to go on with .09 to 1.0a but it takes about 3.5a to turn mine on, so my cpap won't run on it's own. I'll have to run a cigarette lighter from the battery to my bed for the cpap directly off the 12 volt side. Time 2roll, Thanks I'll have another look at the manual, Do you have this inverter? or did you see the manual on line. Thanks, Mel
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
