I just had a Renogy 400 watt solar premium eclipse Kit installed on our 2004 Montana 5th wheel. I had to have it installed because I recently had back surgery. I also had a Renogy 2000 watt inverter/c...
Don't fix what is not broken. Carry the needed 6 wire nuts to bypass the inverter. Put them in a bag and tape them to the back of the inverter somewhere. As you know as long as you carry a spare, the component will not fail ;)
And no you cannot have the wires on a separate jumper back to the breakers. I do not recommend it.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
