OK, so I'm going to add a mild 100w solar kit to my new FW, as a =helper= to give me an extra day or two for our short boondock trips. Biggest concern is the draw from the fridge fan due to it being ...
This Renology kit just isn’t up to the task you are asking but at least it’s expandable. Note this quote: “Ideal output: 500Wh per day; can fully charge a 50Ah battery from 50% in 3 hours (depending on the availability of sunlight)”
Twenty-five amps hours on an ideal day isn’t going to happen and if it does it isn’t going to fill much. Two panels might work, three would, four is better.
