**** yankee1 wrote:
First let me say thank you in advance. Now I will be installing a small solar panel on the roof. I intend to bring the wire down thru the fridge vent. That being said this is the area of my converter and fuse panel as well. I would like to mount the solar control in this area as well. Can I run wire from the solar control to the lugs where the battery cabels connect to the on board converter/charger to pickup battery
If it is a "small" panel then yes. In my last MH I ran 200 watts and it worked fine. But I never used the battery disconnect.
