mike-uswest's avatar
mike-uswest
Explorer III
Jul 21, 2019
Solar question
I have an Arctic Fox 25Y that I bought used, and it came with 2-100 watt Zamp solar panels on it. I picked up a Grape 160 watt panel and got a combiner box and hooked them together parallel. I have been told that the wire used in the Arctic Fox is a 10 gauge hookup to the controller. It has been working fine for over a year, but I am having some shorting problems at the batteries, and need to know if that could be causing any problems?
Mike
  • Zamp solar panels use a two pin (trailer hitch type) connector wired with a non standard polarity. Other vendors that use this connector wire their panels the opposite. Did you check for proper polarity on the new panel before hooking it up to your existing system?
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
