big_buford
Nov 30, 2014Explorer
NinerBikes wrote:
Or create a portable folding solar panel system. A couple of 140W 12V solar panels, some piano hinge, and latches. Mount your PWM charge controller where it will always stay dry, inside the trailer. Short fat wire run from the controller, mounted as close to the batteries as possible, without being exposed to the gasses of the battery vents while charging.
Aiming portable panels will up the efficiency of the panels a lot if aimed 3 or 4x a day. Portable panels make shade a non issue, move the panels out of the shade.
X2 a 40-80 watt on the roof and a portable while in use.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
