wbwood
May 21, 2016Explorer
Solar Questions
Just switched out our batteries (mismatched group 27's) with a pair of Duracell (Deka) group 31's (matched). I have a Renogy 100 watt solar suitcase. I understand that it won't be enough alone to char...
grizzzman wrote:wbwood wrote:westend wrote:wbwood wrote:Likely, but nobody really knows what your power usage is.
200 watts will suffice for my two group 31's, correct?
I have an additional 100 watt solar panel...300 watts total for 210amps total...we are only in the camper in the evening, not during the day....no inverter...all dc usage (fantastic fan, LED lights, maybe an hour or two of 12 volt tv usage, water pump fridge panel, etc)
A typo I assume. (210 amps) A. Its likely you know the answer. I have been doing more then you describe on 200 watts.....so....... :h
