pianotuna wrote:
Hi RJsfishin,
I get 17 amps from 256 watts of panels, if the battery bank is hungry enough. Mppt controller, and series/parallel wiring is what it takes to do so.
RJsfishin wrote:
Quote: I read that you can get approximately 30 amps from a 100 Watt solar panel,
Dream on !! It has to be a very good day if I ever see 18 amps from my 3 100 watt panels. You will seldom if ever see 8amps per panel
I do believe the OP meant 30 amp hours per day with a 100 watt panel , not 30 amps per panel.
