1L243's avatar
1L243
Explorer II
Mar 22, 2021
Solar Questions
I have completed my 500 watt solar install with 2000 watt PSW Inverter. I have a couple of questions.
If your plugged into shore power at a Park would you
Question:
1. Have both the Converter and Solar Charge Controller maintain batteries at same time?
2. Solar Charge Controller only with Converter breaker off?
3. Shut down Solar completely and let Converter maintain batteries?
Question:
When I turn on my Inverter it will energize all the outlets in my RV. I will have The AC breaker off, Hot water heater is on propane as is the refrigerator BUT I will have 3 tv's a 40" and two 24", a satellite box and a portable satellite dish. None of these will be on but will be plugged in.
Do these devices need to be unplugged before turning on Inverter.
Question:
Do you clean your solar panels, if so what do you use?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
