Teleman
Feb 17, 2022Explorer
Solar questions
I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
Teleman wrote:
I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you recommend 4 or 8 brackets per panel? Also I'm using the MPPT controller in my Redarc 40A DC to DC charger which has an input voltage of 9-32V. I need to run the panels in parallel to keep the voltage low enough but that means I need to use 6ga wire to run from the point of parallel conection. Do they make connectors that will fit 6ga wire? Or do I need to splice the cables? Thanks in advance.
