I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
I recommend 8 ga which will provide higher voltage to the controller and allow for another panel if desired.
Your panels have a Voc (open circuit) of 39V+. Your controller MUST have a higher voltage maximum rating. This includes several several more volts for increased voltage due to lower temperatures which increases the panel voltage.
Voc can and does occur due to cloud edge effect or driving conditions, etc.
