I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
Voc math example: I recall your temperature compensation is -80mV/degree C +- 10. Lets use -100mV as an example. This means for every 10 degree C drop the Voc increases 1.0V. ie For every 10 degree C increase the voltage drops 1.0V.
