I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
FYI I decided to wire my panels in serial for several reasons. Reduced wiring loss. With an AC between panels 2 and 3 I have a total of 64' (round trip) of 10 ga wire. This results in 1/3 the amps and 3X the voltage. Clarification - For 3 serial panels vs 3 parallel panels.
Serial panels with bypass diodes also have much better shade tolerance than parallel panels which appealed to me. Almost all panels have bypass diodes and certainly all 24V panels.
