I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
I went up on the roof today to see how I could add brackets. The Z brackets I have require nuts and bolts on the bottom surface of the frame and there is almost no clearance to get to them. But frankly those panels are really on there! I pulled up on them pretty hard and they aren't budging. How would you remove them if you needed to? Painstakingly cut the VHB tape off the bracket with a razor blade?
