I'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...
That's why I don't recommend Z brackets. Cut the bracket in half as high as possible. Add an aluminum L bracket to the panel and drill a bolt hold to reassemble. There is also a flat vibrating blade/saw that can saw the tape.
