TelemanExplorerFeb 17, 2022Solar questionsI'm mounting three 210 watt Newpowa panels on my 30'Class A motorhome. I'm using Renogy Z brackets to mount them to my fiberglass roof. The panels are pre drilled to accept 8 of these brackets. Do you...Show More
CA_TravelerExplorer IIIMar 11, 2022I'd recommend SS sheet metal screws with square drive. About $6/100 from Bolt Depot. I used SS bolts, screws and aluminum brackets. Anything with steel will start to rust at some point.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
