StirCrazy wrote:
Teleman wrote:
Well I used 4 brackets with VHB tape and reading the more recent comments it seems less than ideal. Options are cabling the panels to a solid anchorage point like the roof AC frame. Prying the panels off and redoing them with 6 or 8 brackets. Or?
I wouldnt take anything off now that there on, maybe just add a couple in stratigic locations to stiffen it up.  if you have a diagram where you braced it, I could easily give you my opinion on where to add brackets.
Steve
SIMPLE!  Get some L-Brackets similar to these but tall enough to get to your solar panel side framing:
https://www.lowes.com/pd/ReliaBilt-RB-1-5-IN-BL-W-CORNER-BRACE-4-CT/5001634683
Then, if you want your panels to be more secure than they are now just add 1, 2, 4, etc to each panel (again with VHB tape) and the panels will be guaranteed to be held down better than they are now.
I have 3 RVs and I am in the process of putting solar on the newest one (I've got solar on the other two already).  I put 4 brackets bolted/screwed in (EPDM roof) as well as VHB tape.  I felt good about them so I Dicor'ed everything.  Then, my safety 1st brain told me, "Let's make them a little stronger" so I just added some L-brackets for bonus strength.
The best part?  You can add more brackets in less than 20 minutes.
Good luck!
Chris
