You just need to calculate watts in versus watts out.
When buying a panel go as big as possible. Anything less than 100 watts is a joke. The bigger the panel the cheaper it is on a watts/dollar basis. The best deals will be on panels in the 275 to 330 watt range. For these you will need an MPPT charge controller to match the output voltage to your battery bank.
Don't skimp on the panel or the controller. Get a big panel, get a controller large enough to handle a few more panels. A 60 amp controller will handle 2 or maybe 3 of the large panels.
