1L243's avatar
1L243
Explorer II
Feb 04, 2018
Solar Rule Of Thumb....
I was wondering with so many variables is there a rule of thumb on how large of a solar system you need to keep your batteries charged so not having to run the generator.
The factors I would include is my trailer has LED lighting and a 40" TV. The TV may be used two or three hours a day... I have four group 24 12 volt batteries..
Thanks for any input
  • OldSmokey wrote:
    scrubjaysnest wrote:
    HikeN2Mts wrote:
    One rule of thumb 100 watts solar for every 100 amp hours of battery. It really depends on your usage, you need to calculate the watts of each item you will be using for total watts/amp hours used and what is needed to put back into batteries.
    While the above is the universal rule of thumb; we find in practice 140 watts per 100 aH is a better choice.
    please don't post arbitrary nonsense like this, all it will do is result in frustration and failure for those that adopt it.
    My partners and I just shook our heads this morning.. let me give you an example of why there is no rule of thumb that will work.
    my rv has 960 watts of solar.. so how many a/h do i have ?
    can u guess ? no, there is insufficient data. whats missing ?..
    well two things. 1) Voltage 2) Autonomy
    change any one of those two and your thumb is blown away.
    i do, in fact have a 300 a/h 48 Volt bank of prizmatics
    that new thumb ratio for you is now 3.2:1.
    i dont wish to sound arrogant, but do you understand now why
    a 1:1 rule is just bull ?
    doing it right is very simple, no thumbs required!
    The GP (and the common 1W:1Ah rule of thumb) make the assumption of a "12 V" system, which applies 99+% of the time for an RV, and reasonably applies to the OP's rig, which this discussion is about.
    Translating to those terms, you have a 960/(300*4)= 0.8:1 ratio system, close enough to the 1:1 rule of thumb that your system doesn't make it "bull," but supports that rule-of-thumb.
    Nice try!
    That 1W:1Ah ratio is based on a 12V battery bank.
    Adjusting your bank to a 12V basis gives you a 1200Ah bank. Your ratio is 0.8W:1A.
    And there we are right back at a little under 1W:1Ah. :)
    HTH;
    John
  • OldSmokey wrote:
    do you have a monitor ? i bet u do..
    It is in my signature. I spent my monitor money on more batteries.
    Monitor does not add amp hours or any functionality for me.
    And for all you techies, a pic of my battery monitor.
    Good for you. Your monitor is your brain. An electronic "monitor" is an AR thing in any reasonable system.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
