DSchmidt_2000
May 11, 2013Explorer
Solar so cheap that cells can be wasted
I bought a pair of $1/watt W Solar 45W monocrystalline panels from Solar Blvd which arrived today.
First thing I noticed was there were 40 cells on the panel, not 36 like usual for a '12V' panel, but the open circuit voltage was not 4 cells higher.
Took it outside to do some measurements and when checking shading performance I was VERY surprised to not see the amps drop when I shaded one cell, then another, then another.
Hmm, I don't see blocking diodes on the cells. Blocking some of the other cells, there was an immediate drop. "What is going on?"
Closer inspection showed that though this panel has 40 cells, only 36 are wired up. 4 cells appear to be wired up but are not as seen in the 2nd photo.
I guess it was more important to make a square'ish panel vs a rectangular panel even if it meant wasting 11% more cells. Too bad they were not wired up - would have liked to have used that extra voltage for an MPPT controller.
Performance wise, Isc and OCV matched the label even at 4:30PST sunlight with the panel facing the sun.
Green arrows show cells not wired up
Green arrow shows connector ribbon not extending beyond edge of cell.
