bill-e
Sep 13, 2017Explorer
To run ALL outlets off the inverter you can simply turn off your REC/CON (converter) breaker and plug your shore power cord into your inverter.
No worry about shorting because when you want to use shore power again, you unplug it from your inverter.
There are other more complex ways to accomplish this using a transfer switch an/or subpanel.
I think most people just install a separate outlet or two in the RV and plug those into the inverter. That way the inverter circuit is totally separated from the shore power circuit.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
