SJ-Chris's avatar
SJ-Chris
Explorer II
Jan 27, 2021
Solar trickle charger for chassis battery......Good or bad?
Especially for winter storage, for my RV (and boat) I was thinking of getting a simple 20w solar trickle charger to keep the chassis battery topped off.
I see simple ones like this for ~$25-$30:
https://www.walmart.com/ip/20W-Solar-Panel-12V-Trickle-Charge-Battery-Charger-Maintainer-Marine-RV-Car-T-IT/681175652
They seem to come with simple clips to connect directly from the panel to your battery terminals. No charge controller.
I've been learning more and more about solar for the house batteries (...I've got a 200w system and a 500w system I'll be installing soon on 2 RVs). Those "house battery" systems all of course have charge controllers which makes a lot of sense. The simple ~20w trickle chargers don't seem to come with (generally) charge controllers....just wires hooked up directly to the solar panel clipped to your battery.
My question is: Is it smart/good for the chassis battery to be trickle charged constantly with something simple like this that doesn't have a charge controller? It's hard to find voltages on a lot of these simple trickle chargers (...a lot say "12 Volts", but if they mean exactly 12.0 volts I don't imagine that is useful). Would a constant (....when sunny I guess, so not really constant) 13.0v or 14.0v trickle be okay for the health of the chassis battery?
Maybe they don't need a charge controller because the amps they put out is so small??? 20W seems like it would only put out about 1amp or so.
Let me know your thoughts.
Thanks!
Chris
  • 20 watts is more than I'd be comfortable with--except that it is NOT 24 hours a day.
  • time2roll wrote:
    I have a truck and trailer. And since the trailer has solar I keep them connected. I have the Trik-L-Start connected over the truck isolation relay. Works perfect.
    I think I have a good picture of how that would work...thanks!
    Since I'm going solar on my RVs, I'm definitely going with this approach and just be done with it!
    time2roll wrote:
    20 watts might be too small for a large set of batteries or too large for a small start battery depending on how much sun you get. May want to monitor the situation a bit depending on conditions. I had 15w maintaining 4 batteries and it was never really enough even in sunny so cal.
    I still am curious however (...would apply for my boat, or someone else reading this considering a trickle charger for their chassis battery...) for a ~20w trickle charge kit without a charge controller, is it okay to simply connect those clips to your chassis battery and leave it for weeks/months at a time? Is the current so weak (~1 amp) such that you don't need to ever worry about overcharging/etc?
  • I have a truck and trailer. And since the trailer has solar I keep them connected. I have the Trik-L-Start connected over the truck isolation relay. Works perfect.
  • time2roll wrote:
    Are you going to use this on the RVs that will soon have solar? If so I recommend a Trik-L-Start combiner instead.
    I wasn't sure what that is, but I googled it. Very cool (provided I have solar on the RV for the house batteries, which I will). Seems like this could be hooked up pretty easily in the engine compartment by tapping off the house-battery terminal on the charging solenoid. Is that what you did?
    I would still like people's feedback on my original question about whether or not the trickle charger (with no charge controller) is okay for the chassis battery. (...I partly want to know the question because I have the same question for my boat in storage!).
    Thanks!
    Chris
  • Are you going to use this on the RVs that will soon have solar? If so I recommend a Trik-L-Start combiner instead.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 08, 2025
