OregonTRX4
Feb 16, 2014Explorer
Solar voltage help...
I just connected my solar kit (160w cmp12 controller)and the voltage while connected to the rv batteries reads 16.55v. Is this normal or too high? Sorry but im new to this.
OregonTRX4 wrote:Yes. Sounds like the controller is running in 'pass thru' mode, which no controller should ever do.
input to the controller and output to the batteries measure about the same at 21.xxV at the controller. So is it most likely the controller is bad?
