red31 wrote:
The manual for the newest generation of the sunsaver 10 shows the charge profile like this.
14.4v abs, 14.9 equ, 13.7 float, equalize every 28 days for 3 hrs (jumper set to flooded).
The older manual suggests 12.5A max Isc so it would work with 160 watts.
Same exact drawing in the manual for the $40 LandStar PWM controller line. (and for the other EP Solar lines AFAIK.) Funny that they have the same guy doing their manuals as MorningStar. Wonder who makes the MorningStar controllers--same factory as LandStar? I don't know.
You do get Isc so if that is 12a, (you need a controller with 20% margin over panel rated Isc) your controller needs to be 15a
Actually, 160w should have Isc of 160/130 x 8.2 = 10a so add 2 and you need a 12a controller but the next size up is 15.
IGNORE all these people saying you should have a 10a controller.
RJ is quite right that you can buy a perfectly good 15a controller on ebay for under $20. Just don't believe the "MPPT" on any of those if they claim that feature--they work as PWMs. (real MPPTs even on ebay are more like $100 on up)
